Electro technical rating III/7 and work on Low voltage systems
Dear all. Do anyone know where I can find the regulations regarding what voltage an ETR III/7 certified electrician rating can work on, on ships. From what I assume, they can work on low voltage system under 1000V..
Hi John, yes the ETR III/7 are certified to work on low voltage facilities under 1000V.
https://www.sdir.no/sjofart/re...
This is the descripton for electricians as it is stated in the introduction to the section.
Here is the Norwegian regulation: https://lovdata.no/dokument/SF...
See § 45.
